Like you I am interested in building one of these devices to integrate into my current fuel system. I will build one, but like everything else it takes time. Now I have learned that their are several variations to the device which therefore may yield varying results.
I suggest you begin reading up on the different ways to seperate hydrogen from water in order to find the one that best suits you mechanical skill level plus budget.
Hopefully if I have my unit built sooner than later I can put it to the test and show off some positive results.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
