Old 06-20-2013, 08:04 AM   #32 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
One thing that I am sure most of you are aware of, but it is worth pointing out, is that tires change diameter as they wear. On a 25” OD tire, if you wear it half way (suppose 6/32 tread wear) the radius would change (6/32”)/(12.5”)=1.5%. Thus even if you were able get the absolutely perfect speedometer adjustment done initially, as your tires wear you will start to drift away.
The Following User Says Thank You to aardvarcus For This Useful Post:
PaleMelanesian (06-20-2013)
