Old 06-20-2013, 10:19 AM   #16 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by meelis11 View Post
You can try to include complete math library - it was not fitting when atmega 168 was used (16KB flash space), if you have atmega 328 chip then you have 32KB of flash - you probaly have enough room for math library.
Meelis
Thanks! I may try that.
I've compiled the major steps I will need to proceed with this project:
1. Dust off an old MicroCore11, and turn it into a simple SCI programmer (they call it an "ICSP interface" - how cute!).
2. Obtain the latest MPGuino code
3. Solder an extra set of terminals onto board
4. Construct a testing pigtail that will connect to two MAP sensors
5. Add in-car wiring
6. Modify MPGuino code to include editable parameters relating to add-on MAP sensors
7. Modify MPGuino code to interface with said sensors
8. Modify MPGuino code to utilize sensor readings
The Following User Says Thank You to t vago For This Useful Post:
KY Metro (07-11-2013)
