Old 06-24-2008, 12:50 AM   #24 (permalink)
JamesLaugesen
JamesLaugesen's Avatar
Buell XB12X - '06 XB12X
90 day: 49.02 mpg (US)
Commodore VL - '87 Commodore VL
90 day: 18.93 mpg (US)
Grand Cherokee WH - '06 Grand Cherokee WH (WK Export)
90 day: 15.44 mpg (US)
Originally Posted by ebacherville View Post
if these hydrogen booster lowered temps on the motor that would be a benificial aspect of them even if the don't add MPG.. a cooler running motor does mean its more efficient
I haven't seen HHO lowering temperatures anywhere?
The consesus seems to be that HHO speeds up flame front allowing for a leaner burn (thus hotter) without detonation.
But does that mean the engine will run cooler with no mixture changes?
I've seen on a few forums people who've tried HHO reporting a different exhaust note while HHO is being added (one guy even posted that his exhaust had changed note, and on inspection found that the HHO generator had broken).
A common theory is that combustion is finished earlier before the exhaust values open... could that allow more heat to be scavanged on the exhaust stroke?
