Old 01-02-2008, 05:07 PM   #8 (permalink)
SVOboy
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
6. Take a picture of your spark plugs so you don't forget how they go on,
7. This is where it gets annoying. You'll need to remove the valve cover, the distributor, some hoses and plugs below the distributor, the exhaust manifold, the intake manifold, and the timing belt before you can remove the head. A few of those things are highlight here.
8. But wait! Don't forget to drain your coolant. You'll find this plug under some plastic on the passenger side.
9. Here's some of the junk I advise you to remove to at least push the intake manifold to the side.
10. When I was taking out my spark plugs one of them came apart in the tube. Good thing I had spares.
More in a minute.
