Old 07-11-2013, 10:37 AM   #20 (permalink)
KY Metro
The Odyssey - '98 Honda Odyssey
90 day: 24.45 mpg (US)
The Civic - '98 Honda Civic DX
90 day: 32.5 mpg (US)
Very interested in following this! Thumbs up to T Vago!
I've got a 92 Dodge Dakota that needs monitoring, and it has the Chrysler constant pressure setup. I want to build a custom MPGuino with fuel pressure monitoring.
An added wrinkle... this truck also runs on wood. I start on gasoline and switch over gradually. So to shut off the gasoline I reduce the fuel pump voltage to lean out the mixture as I transition to woodgas. This lowers the fuel pressure and leans the mix, while I simultaneously ramp up the woodgas. Eventually I reach 0 pressure and no gasoline, although the injectors still fire. A stock MPGuino would be way thrown off by this. But if it could compensate for the pressure...
T Vago, will the code be able to reduce the fuel usage to zero at no pressure? That would be awesome.
