I'm currently putting around ... maybe 35 or so miles on the car in a months time ( just to keep the car from falling apart ), so no rush at all to get this done.
Also, I called a shop or two and one fellow stated that I might as well just drive the car as is.
He said that unless I hear 'clicking' sounds when I turn corners , not to worry about it.
Since he made it sound like it was no big deal, I think I might go ahead and clean out the dirty grease ( it's not that dirty really but I want as little grit as possible in there ).
I'll just replace the grease with new grease ( do I need a special type, or is grease ...grease ? )
I'll then try and seal the gaps in the CV boot.
Thanks for the help folks !
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
