How Toyota's Valvematic Works
Been researching Toyota engines recently and my research has found that Toyota has developed a technology called Valvematic, which changes the lift amount based on load.
Because it controls lift, it does not require a throttle plate (which helps reduce pumping losses), but I am of two minds here. Yes the removal of the throttle plate reduces pumping losses, but wouldn't the intake valves just act like the throttle plate, in that they stop/slow air flow, making the pumping losses the same?
Can anybody give me insight into how the system works? What actually makes it open more or less?
Are there any other makes that employ similar technology?
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
