Old 06-26-2008, 06:09 PM   #7 (permalink)
jim-frank
ScabbySentra - '93 Sentra SE
90 day: 44.37 mpg (US)
Keep in mind that the error is proportional to how much you put in the tank. In other words, an error of +/- 0.5 gallons will be 5% if you're putting in 10 gallons, as compared to 10% if you only need 5 gallons to fill it.
Temperature seems to make a notable difference, too. I try to fill at the same time (preferably when it's cool outside) so that doesn't make so much difference.
The Following User Says Thank You to jim-frank For This Useful Post:
johnlvs2run (02-22-2011)
