First trial run in the 93 Metro XFi. I used the "maybe" values listed in your code for the 98 Metro 3cyl. Two things going on that I don't understand:
1. The MI numbers are clicking off in a controlled fashion, but at about 2x what my odometer says. Another forum member had pm'd me that he thought the VSS value should be closer to 4000. Has anyone verfied the 8204 number?
2. The MH figures are constantly increasing when I'm moving, and slowly decreasing when I'm stopped. I assume when they get to zero they'll stop decreasing. Any idea what this is about?
MPG figures are crazy (in the thousands), probably mostly due to item 2 above.
I double checked my VSS input. I am tapped into terminal B15 on the ECU (yellow with green stripe). My injector lead is tapped into the yellow wire right before it enters the connector for the injector resistor.
Any thoughts would be appreciated.
