Old 09-03-2013, 10:54 PM   #41 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Update
Since oil leaking slowly from engine and getting onto parts of the undercarriage has delayed the under tray project, I decided to do the wheel skirts before all the long days are gone. Here are some pics of the progress I made in the last light after work today. I am imitating MetroMPG's copper pipe clip idea, and I am using as much recycled materials as possible.
The coroplast is leftover from my first wheel skirt project. The screws and bolts are from stuff I dismantled, including aluminum screws from the 1950s patio shade I took apart a couple years ago. The aluminum bars for the supports were laying around the garage, leftover from a project. Cutting them to fit was a PITA. I discovered that bolt cutters can make great metal cutters in a pinch, when the snips are just not even close to competent.
Job complete enough to drive it, though I think I will add one more clip per side (for four total on each side) and I still plan to cover over the whole assembly with aluminum sheet and paint it and shade of black closer to the car paint color.
AND HERE IS THE LOOK (at this stage):
ID:	13707   Click image for larger version
ID:	13708   Click image for larger version
ID:	13727   Click image for larger version
ID:	13728   Click image for larger version
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
mikeyjd (09-06-2013), TexasCotton (10-14-2013)
