Old 09-07-2013, 11:24 AM   #6 (permalink)
oil pan 4
I don't have mixing valves, just standard regulators with flow meters, just set the pressures on the 2 regulators with in a few PSI of each other and plumbed them together.
A spool gun is good for 2 things.
Its good for aluminum because soft weak aluminum does not like to feed through a MIG welder handle at the high wire feed speeds that you run aluminum at. It tends to break.
Its also good for switching between fillers, they can save a lot of time if you find your self spending a lot of time switching back and forth between different rolls of wire.
