Old 06-27-2008, 02:14 PM   #18 (permalink)
Magister
OBDuino coder
Magister's Avatar
Titine - '07 Elantra GL
I plan to plug the OBD2 signal (from the freescale chip) on pin 2 and 3 of the board, the RS232 on the board will be used to send debug message on a terminal screen, so you will have to either make an adapter or cut your obd2-serial cable to plug the right pins.
For the moment, no, there is absolutly no "OBDuino" code for the project!! I started to write some code, blindly, as I have no hardware to play with!
