Old 09-11-2013, 01:09 AM   #105 (permalink)
freebeard
Thanks for taking the time, but
slight upward angle instead of a steep downward angle
is ambiguous. Any drawings or pictures. Or just, how would the idler arm theory translate to a tricycle?
Old Mechanic -- Dig the pix. I do hope you use an equivalent grade for the four bolts that hold the axle beam, the holes in the square tube are sleeved and you plug the ends of that crossbar so it doesn't distort.
