Old 01-03-2008, 02:39 PM   #28 (permalink)
IWillTry
Will you?
A bathroom scale may or may not work. Some scales will only work in a horizontal orientation. They also can be difficult to balance on a car bumper (depending on the car). If you do use a bathroom scale, be sure to "zero" the scale while it is in a vertical position to calibrate out the weight of the scale platform. Good luck.
www.IWillTry.org - Will you?
