For next time...You can buy a crank pulley holding tool for about $15 for the Hondas. There are two varieties depending on year. For my 97 civic hx its a 50mm hex thing that you can attach a 1/2" ratchet to. My 1/2" air impact would not remove the crank pulley either, had to use the breaker bar. The other variety has pins that fit into the crank pulley.
