Old 06-27-2008, 10:42 PM   #16 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Sedan 1.6 Base
90 day: 41.69 mpg (US)
I have been doing some research on how to put a tadpole trike together with a motored bicycle engine, and then add a coroplast fairing. This could legally be a moped in MI.
Here is a good thread: My next project - Tadpole Trike - Motorized Bicycle Forum - MotoredBikes.com: The LARGEST Bike Engine Forum on the net!
I think I could put one together for about $3k. I am kind of up in the air over electric or ICE, but either one could work, it just depends on if you plan to use the vehicle and stop every 50 miles to charge or if you want to do long distance travelling.
I think the Staton, Golden Eagle Bicycle Engine or Dax Titan four cycle gas motor kits would all work good, providing at least mid 30's mph and around 200mpg, possibly better with a fairing and hypermiling. If you need faster than that, then you would need to register as a motorcycle and might as well go with something like a Lifan 70 with a three speed transmission, that will give you about 45 mph if geared right.
I am not sure how well this vehicle would fit in with today's traffic, it is wide and will take up a lane, but cannot keep up with traffic on uphills.
One hint on how to acquire a tadpole trike, go to crazedlist.org and get their search function working and do searches for "tadpole" throughout your region. There are numerous tadpoles out there for $1000 or less. A 26" rear wheel will be easiest to add a bicycle motor kit to but other sizes can be worked out as well.
Nissan Versa Aeromods
