Old 06-28-2008, 01:51 PM   #4 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
First, Welcome to EM...
The assumption of 1.0GPH may be a little high, which may effect the cascade of theories. Re-run the calcs at 0.5GPH and you may find a better result for coasting (20 mph becomes 40 MPG, 10=20, 5=10). Or 9999 mpg with the engine off
<Disregard that last statement, unless you are aware of the risks, practiced on a closed course with a professional driver, etc...>
Someone else can help with P&G, but the slow-to-light in neutral seems to be a tried and true method for a variety of vehicles. If I come in too hot, I downshift to force the injectors into "DFCO". The worst scenario is to start from a standing stop.
Another method (not as popular) is to keep up the speed and stop quickly. Your theories would apply here. 100 mpg, 100 mpg, 100 mpg, STOP!
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
