Old 06-29-2008, 02:05 PM   #2 (permalink)
Ryland
Ryland's Avatar
Tomos Arrow - '05 Arrow ST
90 day: 101.68 mpg (US)
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
it should be the same as doing it for a car, or you could go with straight waste oil if you have a oil tank tht is inside, other wise you would need to heat it and even then heating it might be needed, if you had the oil and were just looking for something to burn it in then running a diesel generator and using the waste heat from that to heat your house would be the way to go.
