Old 10-13-2013, 12:51 PM   #3 (permalink)
mort
EcoModding Lurcher
mort's Avatar
Originally Posted by starcr0ss3r View Post
If you had your choice of a car to eco-mod, which would it be: a 2003 Toyota Echo Sedan w/automatic transmission or a 2003 Honda Civic Sedan with a manual transmission? (Looking, of course, at overall fuel efficiency as the goal, here.)
Hi starcr0ss,
The automatic will lose a small amount of efficiency compared to the manual. But the Echo curb weight is listed at 2035 lbs and the Civic is 2403 lbs. I think the weight difference more than makes up for the automatic. EPA: Echo 31 Civic 30 (combined)
The Echo is smaller than the Civic so if you make mods to reduce cda you'll be ahead as far as wind drag too. I'd take the Echo, I see it as a better starting point.
-mort
The Following User Says Thank You to mort For This Useful Post:
starcr0ss3r (10-13-2013)
