Old 06-29-2008, 03:26 PM   #90 (permalink)
reformed
Did you get that thing?
reformed's Avatar
Green Machine - '92 Civic LX
90 day: 39.98 mpg (US)
Money pit - '97 j30
90 day: 22.74 mpg (US)
Forgot about ya saturday. If you still need me to look up the pin output, I'll be at a friends shop on tues and back to my regular job on wed so either way I can get it.
Have you tested the VSS wire with a testlight or meter yet? When I test it, I always just tap a wire into it and then run it to my testlight inside the vehicle, then I drive it and see if it starts flashing the light. The faster you go the faster it will flash. If its shorted, it will be a dirty signal (not clean flashes) or just solid ground. VSS sensors usually don't work in reverse either so test it in a forward gear.
