Yes more surface area will cool the combustion event more and where does that heat go? into the head where the surface area is, so there will be localized hot spots. Overall the increased heat transfer means less efficiency BUT, I am open minded to the posibility that this heat transfer can be more than offset by a more efficient burn if these groves actually work.
