Old 10-14-2013, 10:14 PM   #7 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.23 mpg (US)
I see what you're saying now, it just took me a second explanation to understand. You are choosing when you want the intake to be closed, which determines the compression and the effective size of the engine (or at least effective displacement). Do you have a button inside the car to tell the system what you want or is it still automated?
So, since it is from a Prius, that means you have the FXE? How do you get around the hybrid battery stuff? Is that why you need a different ECU?
I've gotta find me a place that sells these! For $200, experimentation is very possible!
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
