Old 06-30-2008, 12:01 PM   #23 (permalink)
jonr
IMO, CAI will hurt you. A tuned intake system could help you (some?), but only at a a very limited rpm/load range. More applicable to stationary engines driving load controlled generators at fixed rpm.
Low rpm is not an all good thing either - piston speeds are lower so the conversion of heat into movement is less efficient.
