Old 06-30-2008, 01:48 PM   #24 (permalink)
garys_1k
Acoustic effects significant to FE lie between the throttle valve and the intake valves. Nothing upstream of the throttle will change the acoustic tuning at these part loads.
Keep you air filter reasonably clean and you'll do fine, unless you want high RPM power. FE calls for limited amounts of air so efforts spent tweaking out a small pressure drop are most definitely spent elsewhere.
