Old 07-02-2008, 01:16 AM   #404 (permalink)
Blue07CivicEX
NewBlue - '07 Civic EX
90 day: 40 mpg (US)
The Better Half - '97 Ranger XLT
90 day: 25.84 mpg (US)
might have gotten a hair of solder across the pins or just bad buttons, if you really felt ambitious you could de-solder and re-solder one, if that didn't work you could try de-soldering a broken one and the working one and swapping them to see the result, BUT then you run the risk of breaking the third one :-). If your solder job is messy you can pick up solder wick and clean some off, you can also heat up your soldering pen (I hope it's a small tip) clean the tip and draw a line between the solder points this should break any faint connection that might be bridging.
2007 Honda Civic Ex
Second Goal = 50mpg
First goal = 40mpg Goal Achieved 3 tank average over 40mpg
Starting point 30mpg ready...... GO.
