Old 07-02-2008, 04:41 PM   #21 (permalink)
klrv6
Sandstone Princess - '99 Sububan LT
90 day: 21.04 mpg (US)
Joe - '02 sentra XE
90 day: 43.9 mpg (US)
Regal - '03 Regal LS
90 day: 33.85 mpg (US)
Originally Posted by justpassntime View Post
It is so much easier if your car has a atmospheric or barometric pressure sensor.
This sensor, depending on what your particular manufacturer calls it, controls the fuel mixture by sensing the ambient pressure at what ever altitude you are driving. The higher the altitude the leaner the fuel mixture.
All you do is put a 25k potentiometer switch on it and turn it down till the idle speed changes. All you are doing is telling the ECU you are driving at a higher altitude than you really are. There are no problems with warning lights or ecu problems this way.
Just be cautious you don't do to far or you can burn pistons or valves due to higher cylinder temperatures.
I was thinking the same thing. Until you can go into the ecu and tell it what afr to run at, just lie to it about the load it's under. It will go to another *lighter* part of the fuel map and put in less fuel. Just be careful...
