Old 12-28-2013, 08:34 AM   #16 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by Beavinator View Post
I have an Aprilia SR50 that is actually a direct injected 2 stroke. It has a fuel injector that injects straight fuel into the head and there is an air injector in front of the fuel injector. There is an air pump that run off a cam on the crankshaft for the air injector. Oil is injected to the intake manifold right before the reed valves. Its a great system but I would love to find a way to get into the factory ecu and make changes to get more performance out of it.
There was a "Gameboy" cartridge that could tune Aprilia DI systems, you will need to search around a while, there is one place in the US that tunes these from an Motocross perspecitve.
Search around and you should be able to find it.
