Old 07-02-2008, 08:05 PM   #7 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Sedan 1.6 Base
90 day: 41.69 mpg (US)
Try spraying WD40 into it. Shift it and turn it quite a bit. Then drain as much as possible and squirt white grease into it.
I have taken a Sturmey Archer 3 speed apart and it worked afterwards. It is best to do it on a workbench with good light. You need to be in top mental condition to do it as well.
Nissan Versa Aeromods
