Old 07-03-2008, 01:57 AM   #4 (permalink)
justpassntime
What? THIS IS MY GOOD CAR
justpassntime's Avatar
The Japillac - '87 Accord LXi Sedan
90 day: 31.77 mpg (US)
Ranchero GT - '73 Ranchero GT
Spaz - '83 S10 4X4 Tahoe
90 day: 27.53 mpg (US)
Send a message via ICQ to justpassntime
Sounds Good...
Originally Posted by Ville80 View Post
thanks for the tips.
i think i will try to glue the lexan behind the grille. i don't see that i will have to remove it, except for maybe repainting the mesh and bumper in the future. i'll consider some L brackets. maybe 2 for the top. the other sides would be visible on the outside bumper.
How about 2-4 L brackets on top and a couple zip ties to the mesh. hopefully my shop guy can firgure something out if i ever get my mesh to install.
i want to cut into my bumper as little as necessary.
hopefully i can secure the bottom piece it to the bumper with only 6 plastic push screws, 8 at the most. i should be able to get 6 more attaching to the subframe.
Sounds like your on the right track. I don't like cutting or drilling if I don't have to. I usually find away around it, even more important for you since your car is much newer than mine. Good luck.
Honda...the economical, renewable resource.
