Old 07-03-2008, 10:09 AM   #22 (permalink)
lunarhighway
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
i thought they where more to prevent air from being sucked in the wheelwell, as there's a lower pressure on the inside of the wheelwell.
also i've seen versions of these dams up close on certain new VW's like the pasat, that had an opening above them with a naca intake like duct in front of them, wich would lead air above them dams into the wheelwell. i assume this is for break cooling. but this would in my view, limit the effect of the low pressure area behind the dam (as well as prevent high pressure from form in in front of it)
i wish there was some good information available on how these dams actually work... i'm going to install them on my car, but it's hard to make something that works when you don't understand what it should do, and how it does that!
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
