Old 07-03-2008, 01:52 PM   #9 (permalink)
aerohead
interior airflow
Originally Posted by jamesqf View Post
Question for the aerodynamics experts: I've been reading arguments about windows down vs A/C, and just had a thought. You have a high pressure area somewhere at the front of the car, and a low pressure area at the rear. Suppose you take some - potentially a lot more than current vents supply - air from the front, and direct it through the car. You get the same cooling effect as rolling down the windows (if not a good deal more), some "wind in your face" effect a la convertible, no frigid breeze as with A/C... and it seems you'd actually reduce overall drag.
Make sense? Or am I missing something?
Germans beat you to this 70-years ago! You need to track down a copy of Baron Reinhard von Fachsenfeld's "Aerodynamiks des Kraftfahrtzeugs" ( sp? ).It's all in there.I listed the particulars for the book in my seminars and installments.Inter-library loan is a good bet.I had to drive 30 miles to a university and copy it there.Good luck!
