Old 07-03-2008, 02:34 PM   #6 (permalink)
aerohead
engine bay
Originally Posted by Ville80 View Post
that seems like A LOT of work. would that require removing the fans? i can't even imagine having enough space to add the ductwork. I think there may be someone on this forum that is will to try it seeing the tremendous benefits.
so it would be okay to have no airflow over the engine bay componenet? cooling the rad to circulate coolant is enough? my stock setup tries to seal the incoming air at the main grille into the radiator with side fins and closing the top. but the rad extends down to below the actual bumper.
i was planning to add coroplast to keep the air from slamming down to the undertray. but thinking of pressure, unless totally sealed ducting like you mentioned, it will find it's way down there anyway.
I'm thinking just open vents into the wells and a vent behind an air dam below.
I did a complete aero-mod installment for internal drag.You might want to track it down and take a look.If you do a complete racing style cooling system (if you could!) it would be good for a 12% drag reduction and about 6% improvement in mpg.You can way the cost/benefit.
