Old 07-03-2008, 03:00 PM   #8 (permalink)
NismoMax80
NismoMax80's Avatar
Max - '04 Maxima SE
90 day: 24 mpg (US)
ok that makes perfect sense.
seeing how my rad is sealed off in the front, (except the bottom, but will be when i make my tray) how do i determine if i should block my lower grille?
air will enter the top grille and go down to behind the lower grille anyway. if i block it, i still have a pocket since the lower grille opening is recessed. will it be an advantage to having a pocket closed off down there, or the air hitting the lower radiator?
and if it's blocked off, there seems to be a sensor located there. i wonder if that will affect anything?
my current project
