Old 07-03-2008, 09:25 PM   #102 (permalink)
bennelson
Fossil-Fuel Optional
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 26.95 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
Does anyone have suggestions for installing my new volt-meter?
It is an analog needle design. I assume that it will use a very small amount of current to move the needle with electromagnatism.
I am planning on just hooking it up to one of the four batteries, as it is designed for 12-volt use.
Should I have some sort of "momentary-on" switch for it, so it only pulls power just when I need it, or will it take so little power that it doesn't matter at all? I just don't want my batteries getting out of balance. I would imagine it takes a miniscule amount of power, but want to make sure I am doing things right here.
I also realized that I will not be able to hook it up with the standard negative to the frame. I am measuring main pack voltage, something I DON'T want going through the frame of the cycle. I will need to use two wires, going directly to the one battery I want to measure.
My existing wire harness is totally home-brew (and looks it) but uses TWO wires for each device, thus totally seperating the power from the frame.
I am thinking about re-doing the wire harness, now that I know what wires I need going where. I think now, there isn't any good reason not to use the frame as the negative. This will eliminate half the wires in that's rats nest. Also, it will be a good opportunity to make sure I actually have fuses on everything....
