Old 07-04-2008, 03:47 PM   #414 (permalink)
wagonman76
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
SparkFun Electronics
This link was from a few posts back.
I would really like a serial version, but if you are going to a strictly USB version, I could most likely use my computer at work to flash the chip. Ill trust you in what you recommend is going to work best.
I did some reading through my 80s and early 90s GM factory service manuals. From what I can gather, it appears there are a few different combinations, but all with the same result. 1- Cable driven speedos have an optical pickup/module as a VSS, which sends 2000 PPM (pulses per mile) to the ECM. 2- Electronic speedos with non-electronic trannys, have a VSS buffer between the VSS and ECM, and it sends 2000 PPM to the ECM, and 4000 PPM to the gauge cluster. 3- Electronic speedos with electronic controlled trannys go direct to the ECM, and the ECM sends 4000 PPM to the gauge cluster.
Winter daily driver, parked most days right now
Summer daily driver
