Old 07-05-2008, 02:20 AM   #20 (permalink)
ajax_6531
1997 Civic POS - '97 Civic EX
90 day: 33.29 mpg (US)
Send a message via AIM to ajax_6531 Send a message via Yahoo to ajax_6531
Per some good old firefighting info (I'm a volunteer firefighter, too, did I forget to mention that?), using a larger outlet side, you wouldn't have to worry about drag on the inlet side since the greater negative pressure would serve to pull more air into the inlet. The size difference can't be that great, though, because you'll lose the effect.
IYAOYAS
