Old 07-05-2008, 08:07 PM   #5 (permalink)
garys_1k
Originally Posted by Ville80 View Post
Any opinion if i should block the top grille or bottom? using lexan or coroplast?
I like your left diagram with the upper grille block. Sending that air up over the hood is better.
As for lexan or coroplast, your choice -- the air won't care. I find coroplast so simple to work with, and stealthy if you do want to install it on the back of the grille's surface. I've never worked with lexan, though.
