Old 03-02-2014, 08:27 PM   #1 (permalink)
sarguy01
sarguy01's Avatar
Mazda5 - '12 Mazda 5
90 day: 25.22 mpg (US)
Big D - '11 Dodge Durango Crew
90 day: 18.75 mpg (US)
Grill Block 2.25% Increase @ 50 mph.
After the air dam failing to gain mileage, I decided to go another route while I ponder the air dam some more.
I went to Home Depot, bought some 7$ flashing and then made a cardboard template. Using the license plate bracket and some leftover aluminum angle, I fabbed up some quick mounting brackets. I also put some angle inside the bottom grill opening to hold the bottom of the flashing in. Once the cardboard template fit, I traced it onto the flashing. I then used some self tapping screws to hold the flashing to the brackets.
Here is the pic I took.
Coolant temp stayed right at 195-200*, which is normal. I'll be sure to watch it as the weather gets warmer.
After ABA testing tonight at 50 mph, I got an increase of 1.7% one way and 2.8% increase the other way. Average gain was 2.2%. That is about 1 mpg at 40 mpg. Hopefully the net gain will be higher the faster the car goes. I am out of time to test until next weekend though.
It will take a few miles (4,000) to pay off, but I'll take the gain! I am going to paint it black when I get a minute so it doesn't stick out as much.
The Following 8 Users Say Thank You to sarguy01 For This Useful Post:
Cobb (03-03-2014), jeff88 (03-03-2014), mcrews (03-03-2014), MetroMPG (03-04-2014), mikeyjd (03-05-2014), Piwoslaw (03-03-2014), redpoint5 (03-03-2014), UltArc (03-02-2014)
