Old 07-06-2008, 12:33 AM   #23 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Originally Posted by garys_1k View Post
I hope that stick doesn't kick up enough vortices on its own that it messes up the flow over the body. Maybe you should use a chase car and video from that.
As long as the stick is not in the airflow area that he is filming he should be fine.
Trying to get a chase car together is a real pain because it requires three people to do it right : two drivers and a camera-man.
Another benefit of using a webcam is that they are so small that they can be used to do tuft testing underneath the car. ( Or even in the wheel wells if the camera is small enough. )
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
