Old 01-04-2008, 11:21 PM   #37 (permalink)
newtonsfirstlaw
The Mighty Mira - '92 Mira
90 day: 61.32 mpg (US)
Originally Posted by AndrewJ View Post
I agree that the airdam isn't optimal FE-wise.
The full belly pan/undertray thing is not that hard to do. You need a couple 8*4 sheets of 0.6mm aluminum, probably some sort of heat resistant padding to stick in the middle somewhere. Jack stands, your regular jack, a friend, a drill, screws with big heads, some metal shears and about 5 hours is all you will need.
"Every body perseveres in its state of being at rest or of moving uniformly straight forward, except insofar as it is compelled to change its state by force impressed." - Isaac Newton
