Old 07-06-2008, 03:13 PM   #2 (permalink)
gascort
gascort's Avatar
Gascort - '93 Escort Wagon
90 day: 43.01 mpg (US)
probably best to just experiment. I'm finding with my grill block that there's a lot of other stuff (besides the size of the hole) that affects the amount of air that goes through the radiator. Hopefully someone else will chime in - you should check out Andrew's 70 mpg white civic - Improving aerodynamics of 5th gen civic hatchback.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
