Old 07-07-2008, 12:17 PM   #419 (permalink)
BrandonU
The switches I am using are normally-open, 4 pin, tactile switches. The two sides of the switch are each internally connected to 2 pins. I didn't see any markings on my switches to indicate which pins went where, but it was fairly easy to figure out with a continuity tester (or ohm meter). 2 sets of pins will be connected internally without pushing the switch, giving you a "beep" or a 0 ohm reading on your tester. These 2 sets will be either side of your switch. It won't matter which pin of a particular set you choose to wire to. Maybe the following diagram will help. Pins 1 and 2 would be one side of the switch, pins 3 and 4 the other.
