Old 01-05-2008, 04:25 AM   #8 (permalink)
landspeed
EcoModdin' Lurker
Bluey II - '89 Bluebird 2.0iZX
In terms of autos... my 1989 auto actually does care about the TC. When slowing down, it does fuel cut above 80km/h, but once the torque convertor lockup deactivates, it instantly starts using the same amount of fuel per engine cycle as it would at idle - which means it is better to put the transmission into neutral - so at least it 'idles' more slowly.
I've tried doing manual engine-cut using the keys (in gear) once or twice; after a few seconds, when you switch back to 'engine-on' mode, the engine seems to be turning at about 500rpm. I think it is quite bad for the transmission to be honest (which is why, if you have to tow an auto, it must not be in 'drive').
1989 Nissan Bluebird Auto - slowly becoming more economical and more extreme
