I guess I will skip the Max Life stuff if it is thicker.
Well, based on your other responses (don't want to blow up the engine is a good one!), maybe you should look into the Max Life stuff a little more.
I mean, if the thickness and other crap they put in there helps prevent an oil leak, maybe that makes up for a small decrease in mileage.
BTW, I saw a dynorun once where just switching from 40 weight oil to 30 weight oil on a Civic gained 2 hp. So the weight of the oil makes a measurable difference, but not a huge difference (maybe that was a 2% gain in hp).
