Old 04-17-2014, 07:47 PM   #14 (permalink)
Cobb
The insightcentral guys advise powering up the original blower on the bench and once nearly full use .350 ma to balance the cells. You will notice the voltage go up and down as they real 100% capacity. Once the voltage stabilizes after several 15 minute checks its considered balanced.
Plan b is to cycle the sticks or modules with a hobby charger and use the built in delta V feature and note the capacity when a cycle is done. 3-5 cycles is all it takes to help bad sticks.
You should keep the sticks cool, it isnt a contest to see how hot you can get them.
