Old 04-18-2014, 05:15 PM   #15 (permalink)
CT2007HCH
I did manage to over heat 1 cell in a pack. I did some research and the highest temp I could find that was acceptable is 60C or 140F. In Texas the inside of the car can get to 120 so I'm not sure if that is a good number.
The problem I ran into was that I was charging my worst cells at 5A with a 7500mah limit with no fan. I looked when they were at about 7000mah and I checked the cells with an IR thermometer. 5 of the cells were 120F and 1 was 140F. In about 5 minutes it went to 160F and I aborted.
At that point I changed to 3A charge, 6500mah limit and added the fan.
So the problem with a single point temp sensor is you may not be on the cell that needs it.
Here is a really good site that talks about NiMh charging in general.
Technical Tips for NiCd and NiMH Battery Pack Users — CamLight Systems
