Old 04-25-2014, 04:46 AM   #6 (permalink)
Xist
90 day: 29.44 mpg (US)
Originally Posted by NachtRitter View Post
Cracked Exhaust Manifold:
[/IMG]
California is much closer to Arizona, but I already have an HX! Do I really need a VX?!
Will you please describe the manifold damage? I just removed my exhaust manifold and I do not have any idea where that crack is.
I do not know if you saw this: http://ecomodder.com/forum/showthrea...ads-28519.html
but I ended up pulling off the exhaust manifold while it was still attached to the first exhaust pipe in order to hammer a 13mm socket onto a stripped 14mm nut. I put it on a carefully-folded towel, but I did take a sledge hammer to it, and noticed a thin crack afterward.
I believe in doing things right, but I just put JB Weld on it. I hated doing that, but I did not even know if the crack went through the metal!
