Old 07-08-2008, 06:49 PM   #26 (permalink)
aerohead
cracking open the hatch
Originally Posted by RH77 View Post
Has anyone tried this? I'd be curious to give it a shot...
RH77
In the recent past,this would net you carbon monoxide poisoning.With newer,cleaner engines this may not be as big an issue,however,you would still be inviting the the outdoors in and from the direction of your own exhaust pipe.I have carried large items in a hatchback which necessitated propping the hatch open,and I suffered every mile 'til I got to my destination.The reason the cowl is used for a ventilation inlet is that it is at a relatively high static pressure ( NASCAR teams breathe their engines from here ) and the air source is away from the tailpipes of the car in front of you.Engineers try to cite the air outlet such that a relatively constant pressure differential is present across the cabin,rather than building into a hurricane draft,as speed increases.They're thinking air changes more than evaporative cooling.I've used auxiliary electric fans to increase air velocity across me.The proliferation of air conditioning has turned ventilation design away from passive,to forced air systems.Kinda hard to modify.
