Old 04-28-2014, 11:47 PM   #9 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by RobertISaar View Post
i'm..... curious, what kind of advance are you having to run with AFRs that thin? even with excellent mixing/air-fuel charge control, seems like flame speed would be super slow running twice as much air as stoich?
Very good question.
I'm running around 30* ignition advance at 30:1 A/F.
It's a major balancing act trying to keep the A/F ratio lean enough to help with pumping losses, and not slow down the flame speed to where the power drops off and kills efficiency. This is where I found out after a couple try's that I need to introduce flow to the top of the heads intake runner to create a tumble air flow effect. This help a ton with flame speed. I was running around 38* advance before I made this adjustment.
The other thing I found out is the extra back pressure from the turbo help the blow-down and improved efficiency. As flame speed slow down from lean burn the extra exhaust pressure pulled more power out of the later part of the piston power stroke.
Pressure Gradient Force
The Positive Side of the Number Line
